Date:    10-4-2012
Number of Hours:    1.00
Brief Description:    Canopy adjustment; Seat belts
Page 34-12
Step 6: Chamfered with a Dremel and sanding drum the outboard corners of the Guide blocks as required to eliminate interference.
Page 33-02
Step 3: Attached the end fittings of the lap belts to the F-1217C Seat Belt Attach Lugs using the hardware in Fig. 2.
Step 4: Attached the end fittings of the crotch straps to the F-1267A and F-1276B Crotch Strap Lugs.
Step 5: Removed the VA-104-3 Knob; fastened the Seat Ramp Cover and Step Floor Cover using the hardware in Fig. 4. Reattached the knob.
