Date:    8-25-2010
Number of Hours:    2.00
Brief Description:    Fuselage Wiring Harness
Pg. 31-12
Step 1: Routed the remaining wires of the WH-RV12-TUNNEL harness through the F-1206A and F-1207B Baggage Bulkheads.
Step 2: Loosened the System Blocks for passage of the Trim Wires. Continued routing the wires along the same path as the Static Line.
Retightened the System Blocks
