Date:    8-23-2010
Number of Hours:    2.00
Brief Description:    Fuselage Wiring Harness
Pg. 31-12
Step 2: Routed the Static Line forward through the F-1207B and F-1206A Bulkheads, fuel pump cushion clamp, F-1204 Center Section Assembly, F-1276C System Blocks, F-1203A and F-1202F Bulkheads, fuel flow cushion clamp, around the back of the Rudder Pedals and up through the F-1202B Panel Base.
