5-24-2010 |
3.00 |
Miscellanea |
Reprimed sanded areas in the baggage space. Tried rolling on 3 coats of Top Secret paint onto a test piece of aluminum using a foam roller to see if it would smooth the surface. It left numerous little bumps on the surface. Painted a coat of Krylon Clear Polyurethane on the flap handle and air vents. This paint leaves a yellowish cast to the paint. I may have to remove it and start over. Removed the masking from around the footwells. |
