Date:    4-4-2009
Number of Hours:    2.50
Brief Description:    Emp. Att. Pg. 11-7 Stp 1-7
Step 1: Bolted Clevis Plates together.
Step 2: Match-drilled the holes from the Clevis Plate into the Push Rod and Deburred.
Step 3: Clamped the Threaded Insert onto the end of the Push Rod.
Step 4: Match-drilled the holes through the Push Rod.
Step 5: Riveted the Clevis Plates and the Threaded Insert to the Push Rod.
Step 6: Installed the Rod End Bearing into the end of the Treaded Insert.
Step 7: Attached the Rod End Clevis to the Servo and adjusted. secured with jam nut.
Will do servo testing later.
