6-4-2009 |
8.00 |
Wing Flaperons Pg.18-3, 4, 5 & 6 |
Pg 18-3 Right Flaperon Step 6: Unclecoed all parts and deburred all holes matched or final drilled in the parts. Pg. 18-4 Right Flaperon Step 3: Riveted the A-1208 Bracket to the Inbd Nose Rib. Step 4: Clecoed the two Pivot Brackets and the Inbd Nose Rib Bracket Assy to the Spar. Step 5: Inserted the #10 bolt in the A-1208 Bracket and Actuation Bracket using 8 An960-10 washers for spacing and secured with a nut. Step 6: Aligned the Actuation Bracket and Pivot Brackets perpendicular with the top of the Spar then match drilled #30. Clecoed the drilled holes. Step 7: Removed the brackets and deb urred the holes that were drilled. Pg. 18-5 Right Flaperon Step 1: Riveted the Actuation Bracket and Pivot Brackets to the Spar. Step 2: Clecoed and riveted 10 Main Ribs to the Spar. Step 3: Clecoed the Inbd Nose Rib Bracket Assy, Inbd Nose Rib, 2 remaining Main Ribs and the Outbd Nos Rib/Counter Balance Assy to the Spar. Step 4: Riveted the clecoed parts to the Spar. Pg. 18-6 Right Flaperon Step 1: Clecoed the Inbd and Outbd Flaperon Skins to the Main Ribs and Spar, assuring the skins laid flat on the ribs. Step 2: Riveted the Outbd and Inbd Flaperon Skins to the ribs and to each other. Step 3: Clecoed the outbd Nose Skin to the understructure, except along inbd edge |
