Date:    5-21-2009
Number of Hours:    6.50
Brief Description:    Flaperons Pg. 18-2, 18-3
Pg. 18-2
Step 1: Completed Actuation Bracket by drilling holes.
Step 2: Refabricated two more Pivot Brackets.
Pg. 18-3
Step 1: Clecoed the Spar , Outbd. Nose Ribs, Counterbalance and Outbd. Nose Skin.
Step 2: Match drilled #30 the the Most Inbd. and most Outbd. Nose Ribs using the technique previously decribed.
Step 3: Unclecoed the assy. and deburred the holes in the Counterbalance.
Step 4: Riveted the Lt. and Rt. Counterbalance Weights to the Outbd. Nose Ribs. Used the wedge technique to pull the rivets with the close quarters hand riveter.
