Date:    5-2-2009
Number of Hours:    6.50
Brief Description:    Stall Warning Pg. 16-3, 16-4
Pg. 16-3
Step 1: Made the 5" long ground wire for the Stall Warning Switch.
Step 5: Removed the Mid Wing Skin.
Step 6: Made the 68" longTerminal Wire for the Stall Warning Switch.
Step 7: Installed the Terminal Wire and Ground Wire onto the Stall Warning Switch.
Pg. 16-4
Step 1: Cut 2, 12' lengths of string.
Step 2: Routed the strings through the Snap Bushings and taped the ends.
Step 3: Attached a connector to the inbd end of the Terminal Wire.
Step 4: Made 2, 5" Terminal Ground Wires and attached connectors.
Step 5: Attached the Terminal Wire and the Ground Wire to the L Terminal Bracket.
This concludes Section 16.
Step 6: Attached the other Ground Wire to the R Terminal Bracket.
Step 7: Installed the Terminal Brackets onto the Outbd Nose Ribs.
Step 6:
