Date:    4-21-2009
Number of Hours:    8.00
Brief Description:    Wing Ribs Pg. 15-2, 15-3
Pg. 15-2
Step 1: Completed fluting Nose Ribs.
Step 8: Separated the Hinge Ribs and deburred.
Step 9: Installed 3 Nutplates into a L and R fwd and aft trimmed Nose Rib.
Step 10: Installed 2 Nutplates into one R untrimmed Nose Rib.
Pg. 15-3
Step 4: Clecoed the L Rib Doubler to a trimmed L Main Rib. Match drilled the #30 holes into the rib and deburred the holes.
Step 5: Clecoed the R Rib Doubler to a trimmed R Main Rib. Match drilled the #30 holes into the rib and deburred the holes.
Step 6: Clecoed Hinge Bracket Assys. and L Hinge Ribs to two R Main Ribs. Match drilled the #30 holes into the Main Ribs and deburred the holes.
Step 7: Clecoed Hinge Bracket Assys. and R Hinge Ribs to a fwd trimmed and an unmodified Left Main Rib. Match drilled the #30 holes into the Main Ribs and deburred the holes.
