8-22-2012 |
4.00 |
Service Bulletin 11-12-14 |
Continued removing paint from the tank skin in the locations for the inboard and outboard clips. Step: 4 Drilled off the two K1000-3 Nutplates that were attached to the aft side of the T-1205 Fwd Tank Bracket. Page 37-02, Revision 1, Fig.3. Step 5: Positioned the T-0008 Inboard and T-0009 Outboard Clip against the T-1201 Main Tank Skin. Page 37-02, Revision 2, Fig. 3. Marked the rivet head attaching the main tank skin to the T-1202 Fwd Tank Bulkhead to clear the installation of the T-00008 Inboard Clip. Marked the two rivet heads attaching the main tank skin to the T-1202 Fwd Tank Bulhead to clear the installation of of the T-00009 Outboard Clip Drilled out the three marked rivets. Step 6: Clecoed the Inboard Clip and Outboard Clip to the aft side of the Fwd Tank Bracket and Main Tank Skin. Page 37-02, Revision 2, Fig. 3. Match-drilled #30 the main tank skin using the holes in the inboard and outboard clips as templates. Unclecoed the clips and deburred the new holes. Primed the clips. Step 7: Riveted the Inboard and Outboard Clips to the Main Tank Skin. Page 37-02, Revision 2, Fig. 3. Coated the mating clip surfaces and rivet shop heads with fuel tank sealant. Step 8: Riveted one of the nutplates to the Fwd Tank Bracket and Inboard Clip. Page 37-02, Revision 2, Fig. 3 Riveted the second nutplate to the Fwd Tank Bracket and Outboard Clip. Page 37-02, Revision 2, Fig. 3 |
