11-13-2010 |
5.00 |
Odds and Ends |
Torqued and sealed the Control Stick push rod bolts. Inserted cotter pins in the Control Stick swivel bolt/nut assemblies and the Stabilizer cable to Control Column bolts. Pg. 24-06 Step 4: Riveted the F-1254 L & R Support Frames to the Roll Bar Assembly and F-1234 L & R Canopy Decks. Pg. 25-05 Step 1: Clecoed the F-1277 L& R Fwd Turtle Deck Skins to the Fuselage and Tail Cone Assembly. |
