Date:    7-30-2010
Number of Hours:    3.00
Brief Description:    Miscellaneous
Torqued bolts/nuts on Torque Tubes and Torque Arms. Used torque seal on all nut and bolt torqueing.
Removed clecoes from Baggage Corner Skins to prevent damage to the skins when the fuse is placed on it's side. The Corner Skins lock in place and can't move anyway.
Filed a small amount off of the ends of the Rear Stub Spars. They may be bottoming out in their sockets, causing the tight wing installation.
Replaced the lower bolt in the Rudder Hinge Assy with a AN3-10A bolt. I ran short of 10A bolts and ordered more. Torqued the nuts on the top and bottom hinges and torque sealed.
Tightened the bolts on the Rudder Pedal Assy attachments and torque sealed.
