9-29-2013 |
8.00 |
VPX Configuration, Flap sensor, electrics |
Today started with a really fun process. We fired up the VPX, updated the configuration and firmware and then confirmed the function of all of the switches. And as a testament to Paul's diligence, everything worked first time. No changes or SMOKE...... :-) He then got onto the GTN650 loom for the Fast Stack hub. In the meantime I worked on fitting the Flap position sensor and getting an understanding of the nature of the functionality of the VPX and its reflex position arrangement. Opened up a couple of grommets and allowed for additional room for other wires. All I can say is it is getting to the pointy end and over the next few weeks I should be fitting the exhaust. This will make sure I have the cabling and liquid tubes in the correct position. :-) |
