Date:    7-14-2013
Number of Hours:    4.00
Brief Description:    Cowl Baffling commenced
Today I focused on the baffling and slowly adjusted the baffling to fit the cylinder heads and the engine in total.
I needed to adjust most of the partsonly a small amount to fit onto the engine. I am now very happy with the result and the final fitting of the side panels.
I have had some discussions with Paul, Dad, and Chris (my brother) about the best coatings for the baffling.The coating fell into the options of High temp paint or powder coating....
In the end I decided to test out the high temp paint first and see what the result looked like then if it was good, I would continue otherwise I would go to powder coating.
