3-12-2013 |
2.00 |
Right rear window |
#&**&$##&^%)(*^)*&$%$%)(* bugger........ I tried to fit the right rear window tonight in a fair degree of heat and although pre-fit was excellent, the glue has hardened a little too much before I got the window into position and as such there is a lip that exists at the top edge of approx 1mm. I am in two minds weather to cut it out and redo, OR, to sand it back, glass the edge and move on. Only time will tell. UPDATE: !! I have priced the window for delivery and found the following: Vans: Rear window cost $140, Shipping: Approx $220 Weld-On: $15 Shipping: Approx $220 Together: Shipping: Approx $350 Rear window direct from Cee Baileys with exactly the same tint etc... AND fitted Cost: $130.00, Shipping $137.50 Awaiting on a Weld-On-10 alternative supplier. Once identified I will install a replacement. |
