12-26-2012 |
6.00 |
Fixing Doors ready for covering |
During my installation of the central cam lock from Planearound, I made a cut into the door section to accomodate the travel of the pin rod. This was due to the fact that I decided to have a rivet stop for each of the rods, not just one. The byproduct of this change in design, was that the hole needed to be covered up. Also, I have noticed on most sites that the attachments for the door hinges are also covered up, so as part of my "finish door ready for upholstery, I did them also. The tool that I have made allowing for the step bolts to be inserted later, will also allow me the ability to tighten the hinge bolts. |
