3-31-2012 |
8.00 |
Flap Seals, Control Rods, |
Today I got onto the riveting of the W-1021-L/R flap seals and noticed that I could not get anywhere near the ones theat were in the closed up section. But with the 'good ol web' was able to find some info to help me. ------------------------------------------------------------------------------------------------------------------------- From: Tim Lewis To: Van's Tech Support Subject: RV-10 QB Wing difficult-to-reach rivets for W-1021-L/R Send reply to: Tim_Lewis@msm.umr.edu Date sent: Sat, 04 Dec 2004 15:20:53 -0500 Van's, I'm attempting to rivet the W-1021-L/R flap gap seals on my RV-10 QB wing. It appears I'll have significant difficulty reaching in to buck (and inspect) the inboard 5 or 6 AN470AD4-4 rivets because the bottom wing skin is already riveted in place. Is it acceptable to use LP4-3 rivets in this location? Thanks, Tim Lewis -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 700 hrs RV-10 #40059 under construction ----- REPLY --------- From: "Bruce Reynolds" To: Tim_Lewis@msm.umr.edu Date sent: Mon, 6 Dec 2004 14:39:22 -0000 Subject: Re: RV-10 QB Wing difficult-to-reach rivets for W-1021-L/R Priority: normal Tim, You guessed right, use LP4-3 blind rivets on the gap seal. Bruce Reynolds brucer@vansaircraft.com ------------------------------------------------------------------------------------------------------------------------- Should be in the plans though..... :-) Also completed the control rods and the aileron actuator controls that are fixed to the wing root. |
