Date:    1-21-2010
Number of Hours:    2.00
Brief Description:    Worked on trim tab.
Used Mark Ziegler's bending blocks. Removed vinyl from trim tab and marked bend lines. Bents tabs. Clecoed E-607PP to the inside bottom surface of E-619PP-1-020. Clamped E-718 to E-717 and ran clevis pin through hole. Clecoed to skin. Match drilled.
