The Pitch servo bracket can use some existing rivet holes so I drilled out 3 floor rivets and two upper rivets. Added 5 additional rivets to complete the mounting. The floor holes were already dimpled so I just countersank the mounting bracket there. Had it off and on several times to position the safety stops where I think they will eventually be. Each shift of the safety bracket moves the stops 18 degrees. Easy enough to re-do after I connect the control tubes for their permanent throw once the elevator is rigged. Will use DB9 connector for the servo wires, except the power wires go to a different place. There will be a Dynon DB9 hub back here to connect the two autopilot servos, the two ADAHRS and one network cable carrying the signals to the Skyview.
