Date:    3-8-2013
Number of Hours:    2.00
Brief Description:    Parking Brake Cable Install
The cable is closer to the control cable diameters for this T handle with a center push button lock and its bend radius is greater than the typical heater cable. The parking brake is up high on the firewall and I had to come down from above to activate it. After playing around with all sorts of mounting options, the best for me was to mount the T handle on the panel centered 16 inches left of centerline, at same height as switches (1 inch above bottom of panel). The T is 2.25in wide and the pullback is 2.75 inches to have the parking brake lever hit the limit stop locking in the brake fluid (if I remember to press brakes before pulling the handle). Trimmed the cable from 8 ft to about 5 feet. Oh, and I chased the little ball bearing and inner spring all over the garage floor when I pulled the cable out to cut the sheathing. Didn't know about those little things inside the cable. Do now! The push button is positive lock so no cable creep.
