Date:    10-12-2010
Number of Hours:    3.00
Brief Description:    Prime Flaps Prior to FINAL Assembly
I had decided to prepare both flaps, both ailerons, replacement main outer rib on right wing, electic aileron trim assembly and wing inspection cover and then prime everything. Finally, I am completed and this is the first set of equipment to get primed. Gosh it feels good. I know the end of the wing is getting very close now.
