Date:    8-3-2020
Number of Hours:    4.00
Brief Description:    Right wing F699 bracket
Completed install of all bolts in the wing spar. The fabricated F699 fuselage bracket was installed too. I don't know why the design has this specific spar AN3 hole directly in front of the floor stiffener angle which is what needs stabilized reinforcement. It leaves no ability to directly mount to the floor angle. I fabricated 3 spacers from .125 bar which pushed the F699 3/8 inch away so everything could be drilled and mounted.
Last picture is the hardware drawer which held all 20 close tolerance spar bolts for 10 years. It was a pleasure to see all the protective caps and tubes without their old friends. I recycled all that plastic!! :):):)
