Date:    3-25-2018
Number of Hours:    6.00
Brief Description:    Fit wings to fuselage 2nd of 4 times-1
Dropped 4 plumb bobs and started setting correct sweep. Left wing good for now. Right wing outer plumb bob was forward one inch from the line. Wing would not go back. Looking at the 1/8 inch F605 bar coming out of fuselage, it was clearly too long and it was hitting the wing rib. I wanted to know how much change at the rear spar would impact the outer wing sweep. Couldn't go deeper, so I inserted 1/8 spacer to push the wing even more forward. 1/8 inch changed the sweep 9/16 at the wing end. I assume if I take 1/8 off the interference, it will allow the same 9/16 reverse sweep. Actual experiment also showed that if I added .200 spacer, the wing went forward a full inch. I just couldn't bring myself to take off .200 from the obstructiing fuselage F605.... yet.... I was concerned with having SOME kind of margin for the ultimate 5/8 edge clearance minimum when drilling the eventual 5/16 bolt hole here.
