Date:    3-6-2018
Number of Hours:    3.00
Brief Description:    Remove Wood Spar
I've waited for this for a long time. Took a couple hours removing all the attaching bolts that held the wood spar halves in place, as well as everything that gets bolted to the spar. Can't wait to start on the wings install. I remember now how tight some of those spaces are. I'll have to read up again on the areas to plan ahead for. If you don't do it right, you'll be taking bolts out and doing it over. So the wings really only need 4 bolts each side to square it up for setting sweep and incidence. And, as I remember, they have to slide out and back in at least three times before its ready to bolt completely up. I'm getting energized again.
