Date:    5-12-2015
Number of Hours:    0.00
Brief Description:    Audio Jacks Install 2
Copilot side. On Pilot side, I brought the PTT and PTT Lo (ground) wires forward from the stick wire hub. One joins the Audio Lo (ground) and the other joins the PTT tip wire. DON'T forget to add a couple layers of heat shrink to each wire before soldering to the Mic jack. Otherwise you will have to remove then resolder the wires to accomplish it. Each wire has two heat shrinks, one small and one larger to cover the solder connection and still shrink tight against the smaller heat shrink under it. An even larger piece goes onto the cable before any soldering so it can come foreward and cover the three heat shrunk terminal wires a little. This side cleaned up nicely with wire wrap around the Dynon spare battery. I'm happy.
