All panel switches work now. Hurrah!! I daisy chained a common firewall ground for all bottom panel switches, and again, for all top left switches. Blue connectors were used to chain two 22AWG wires along each switch. Reds were used for single wire end of runs and also for the VPX switch J2 connector runs. I temp used green (ground ha ha) tie wraps to bundle all the wires along the switches. Each single wire is flimsy. All together they are quite stiff and strong. I like it. I will replace the tie wraps with lacing chord as I wrap up the wiring harnesses soon. Remember, all VPX switch runs carry virtually no current. They internally ground in the VPX which then applies power to the power pin connectors going to the various places.
