8-27-2014 |
2.00 |
Install Baggage Tie Downs 2 |
Finished the pilot side fore and aft tiedowns. I like where the aft ones are installed because when you remove the spring loaded rings, the permanent base mounts do not project into the baggae area. They nest in the valley between two rear wall stiffener ridges. For the forward attachment, just like with the smoke tank on the co pilot side, my Bison bag needs to be clear of the attachment too. It all is good. |
