After I ran the Dynon network cable forward and cut it to length, I had enough leftover to make a correct length Network cable connecting the ADAHRS units to the Dynon Hub (mounted below them). A shorter 3 ft network cable I was using needed to be 5.5 feet to route it over down and back to the Dynon network hub. I had fun cutting, stripping, crimping, and heat shrinking network wires today. Sweat drops clouding my vision while I tried to feed the DSub pins onto the stripped wires were my only real problem. The finished cable was secured and plugged in. Testing proved I did it correctly.
