5-24-2014 |
5.00 |
Skyview System Wiring 2 |
You don't get this far without doing the network setup with necessary devices wired. (EMS, ADAHRS, Arinc, Skyviews). I experimented with screen layouts. I couldn't' get Skyview to update to version10.1. Dynon advised to manually load each new file because of my original firmware version. That worked and I could finally comply with Technical Service Bulletin 031413. The MAC address of each skyview device indicated they had to be returned to Dynon for free repair of a defective printed circuit board. I applied heat to #2 and #4 exhaust pipes and under the #4 cylinder to see if the EMS detected the heat changes. It did. I also decided to splice all the Skyviews' serial lines, the serial devices, and some skyview audio outputs together above the radio stack in the middle of the panel. The wire harness will cross there and is easily accessible for maintenance. Pictures later. |
