1-1-2014 |
4.00 |
GPS Antenna Tray FWF |
Benefits are no external drag, no need to run antenna wiring from aft of spar to forward of spar, no clutter sitting on top of dashboard, uses existing through-the-firewall wire routing. Supplies: 2 DWG-14 adel clamps. 1 .063 angle 7 3/4 long. 1 mounting tray .063 4" x 7 3/4". 9 nutplates #8. 2 ea #8 flush screws,washers, metal locknuts. 8 #8 machine screws to mount GPS pucks (Garmin gave me 4, Dynon did not. Need to get some longer SS ones.). 1 #8 pan head machine screw. Mark one hole for each antenna, drill that hole #19, drill a 5/8 center hole for wire access, mount using that one hole and then use the antenna to exactly locate the remaining holes. Everything will then fit perfectly. To drill the nutplates I just screwed a machine screw into the nut plate to tighten it to the tray and match drilled the nutplate 3/32 holes. Countersink the 3/4 angle for 2 flush screws to attach to the 2 adel clamps. If you plan ahead, 4 of the antenna puck mounting holes can use the 3/4 angle for nutplates. Crimped a TNC connector to the RG400 and cut off a 7 ft length to connect at the GTN750 with a BNC connector there. Primed, painted and mounted. Secured antenna wires to engine mount with adel clamps, then through the firewall with the rest of the wire. |
