Date:    10-14-2013
Number of Hours:    4.00
Brief Description:    Install Engine Baffles 7
I made the initial cuts which left the baffles 7/8 inch surplus metal. Then, using paper clips and pushing the cowling down on the baffles, I was able to determine and mark a 3/8 gap on the sides and rear baffles. Cut those to finish mark and then repeated that process by mounting the forward two baffles that mount behind the spinner area. So, now I have all the baffles with a 3/8 to 1/2 gap for the rubber seals to flex against. The paper clip idea was a great one. You let the cowl push the clips down, still maintaining a flush contact, and then go along each one, measuring 3/8 inch down and mark the final trim line. Next up will be mounting the forward ramps and trimming them to match up to the cowl inlets.
