Date:    5-22-2013
Number of Hours:    8.00
Brief Description:    Install Engine Baffles 3
The baffle kit was prepunched for a scat tube to come out the back of cylinder 3 and go down to a heat muff, then to the cabin heat valve. My setup with the Superior cold air sump and xover exhaust did not allow me to use that opening. I fabricated a cover piece and drilled it in place. That will block off that opening and I will make a new one in front of cylinder 1 on the inlet ramp. Mounted this cylinder 3 corner for fitting. The rear top that goes over the crankcase halves needed trimming to match the curvature. More later.
