3-28-2013 |
0.00 |
Airplane mover - Center Tunnel work |
The light weight airplane mover arrived. Nice piece of hardware. I changed out two shorter attach bolts with the longer ones plus bushings provided and practiced moving the plane. Way easy now. If you could have seen me previously trying to back it up into the garage after a day outside you'd laugh. Move two feet, the front wheel clocks. Lift up on front, reclocking wheel and move back somemore. Repeat. Repeat... Now, this baby gets moved with extreme ease. Also started clamping up the center tunnel parts to prepare to trim the blue stuff seriously with the Andair fuel pump/filter assembly being much more compact than the other brand. The housing will be lower. I also will adapt the whole thing to the RV-6 spar vs the RV-7 spar it was designed for. |
