3-28-2013 |
2.00 |
Added fittings to mechanical fuel pump |
Old drain line was replaced with the standard Vans supplied drain line on the mechanical pump, facing 90 degrees down. Also, the pump outlet fitting was removed and I attached the Vans outlet. The red plug is where the fuel pressure line branches off the pump to the pressure reader mounted on the firewall. |
