1-31-2013 |
2.00 |
EMS and Manifold Pressure Devices |
I used a vertical angle strengthener to mount the Dynon EMS Module. That angle also supports the VPX mounting structure so its double duty. I realized I need to change the mounting hardware to button head 10/32 because the bolt heads are too close to the EMS module for a wrench. Dynon manual points that out. The Manifold pressure module is mounted on the pilot side near the bulkhead fitting. I tried a piece of plastic tubing to see how it will flow. Its good and I will see what permanent type of tubing is required plus some hose clamps. Also primed, painted, and riveted the VPX mounting structure so that area is rock solid now. |
