Cutouts went much easier than I anticipated. The corners remained attached and I went back with a hack saw blade by hand and extended the cuts into each corner. Filed all surfaces, scotch brited the edges and used a mini round file to relieve stress in the corners ever so slightly. The trays snug up just right. Here I have them propped up with my wallet . Might as well. My wallet is on a first name basis with them. I am extremely pleased with how its going. My angle Dremel cutter started acting funny so I have to see why it does not engage, and then I will cut out the other Skyview. After that I will put the panel in the airplane and fit the two panel ribs and center stack together so I can mark for attachment holes.
