4-6-2012 |
1.00 |
Drilled NACA vents to fuselage |
There is the slightest curvature on the fuselage skin along the top side of these NACA vents. I know proseal would hold it tight but I wanted some insurance. So, I drilled symmetrical 4 holes on top and bottom. When the vents get prosealed in place along with these rivets it will be absolutely solid. I put doubler riveting strips across the inside top and bottom rivet area to reinforce the NACA vents where they get riveted. |
