Date:    1-21-2011
Number of Hours:    1.50
Brief Description:    Rivet Top Wing Skins
Its time to close up the wing. I finished all trimming of overlaps. Did a final check of level in the jig. Pulled the electrical conduit through the ribs except the 3 most inboard ones. I will add those one at a time after the inboard bottom skin is riveted on. This is a great day. I hope to finish up the top skins this weekend and then clear off the wooden support and leveling jack from the bottom so I can fit the ailerons and flaps.
