Date:    11-17-2016
Number of Hours:    5.00
Brief Description:    Coffee can air-filter in new spot
I tried to mount the can in the 1 choice spot and it will not work out, so out it came and new brackets made and now it is in a new spot with the carburetor in line with the out flow in this case.
Sometimes things will be built twice but that’s how things go being this is my first plane I’m building.
I got out the last flange and worked on mounting it to the carburetor this should work out ok, air goes right in. The system is all 3” and the carburetor intake is only 2.5” there should be lots of air available when needed.
