Date:    2-28-2016
Number of Hours:    5.00
Brief Description:    Header tank reinstalled, engine bolted on.
I got the header tank bolted back in and all the fittings tightened up. The mount that came with the engine fit the bottom of the firewall so nice, the top mount worked out very well also. The oil lines had a new bracket made and that was bolted on also.
The next thing is to make the air plenums for the top of the engine and connect to the NACA outlets. This should be fun figuring this out and making it all work. The goal is to have all the air go through the head fins and not out any gaps
