4-25-2020 |
4.00 |
Door locking rods and assembly. |
I cleaned out the door locking rod receivers with a file from all the primer and paint from the build. It took a bit of time tweaking everything for the final assembly. I had to heat the one panel once removed with 500w lights to bend down with lined gloves so it would touch the window. Co-Pilot door is close to completion now and a few thing on the Pilot door. Oh use RV silicon to glue the window moldings to the door. |
