Date:    2-14-2013
Number of Hours:    2.50
Brief Description:    Install door gas springs
It was time to mount the gas springs for the doors. I set up both doors to find that the pilot side was down the door then expected so I made adjustments to have the co-pilot side as the starting point and go from there. I tried to level every thing as I could and it turns out very good. The co-pilot door did not line up with the gas shock in place so heat was added twice 20 minus and 35 minus to make the adjustment.
