Date:    12-9-2012
Number of Hours:    2.50
Brief Description:    Cut fuselage for hinges
On this part I put the doors into place and marked out where the hinge tabs will go and trace out. I then cut with the air angel grinder cut disc. This is a great tool for doing this stuff of work. I picked up the anvil and cut discs from Lorco down town to help with jobs like this. I then started to grind and sand out the openings for the hinges with a dermal tool and the angel grinder with sanding disc.
