Date:    4-17-2019
Number of Hours:    3.00
Brief Description:    Static port made and installed.
As to the manual, aluminum tube bent and sanded, fuselage cut and foam removed, Spot-lite bondo used to hold in place, micro and 2 bids to seal the deal. Drilled 3 holes and plugged from inside with 5 minute epoxy and milled fiber, peel-ply added to have a smooth surface and to stop sagging down. The holes were cleaned up on the outside.
One more thing off the list. 2,000 to go
