The vinyl work on the vanity panel was completed and then I had to get the holes opened up were the screws go through the panel. I had to install the vanity panel pieces to see what it would look like, to me this will work as a completed interior panel. I have to make holes for the seat belts to pass through the vanity panel and a shield to go around the belt to seal the hole. Belts are on order from the Velocity factory. One more job almost done, there is work at the front were the wirers come up and the throttle cables are. The carpet came in and that will be cut but not installed just yet.
