Date:    3-26-2017
Number of Hours:    2.00
Brief Description:    Prep for throat, mixture and propeller cables at i
Well I got some time in on the plane today. I marked out a few times on the instrument panel to have the right location and size for the cable cut out. I did a triax carbon lay-up for the cables to bolt too and will unscrew if I need to remove the panel for maintenance.
