Well I gave up trying to fit the frames that came with the plane. They were so far off that a magician would have their job cut out for them. I cut bid today from the end of my roll and it was just enough to do the job. The window was taped up and marked for the bid to go on. 4 bids were applied to the window to make a frame. I did in 2 lifts with 2 bids per lift. Cynthia asked if I was closing in the window and I said that I was making frames for the windows and upholstery would go onto the window frames. Cynthia also said that she could not believe that I was building a plane. I will that that as a positive note.
