Date:    10-13-2016
Number of Hours:    6.00
Brief Description:    Brackets for main gear doors
It was time to work on the brackets that hold the gear doors at the spindle end of the gear. I bent to fit and had to weld on some aluminum extensions to make it all work. I’m glad I picked up the tig welder that can weld aluminum.
The nut plates were added to the doors for the spindle brackets and I got the bracket from the main gear to the door on the pilot side done as well tonight.
