Date:    11-19-2015
Number of Hours:    4.00
Brief Description:    Hinge arm installation and set up
Tonight I marked the canard trailing edge and cut to width and cleaned up from the other biding day on the ends. The tool to mark the 11-7/8” was very helpful in getting the right width all the way down the canard. Once marked the cutting and sanding was next.
I bolted up the hinge arms and got into position for were they are to go. Next will be to cut the skin and remove foam and glue into place.
