10-12-2015 |
5.00 |
Sand and prime Canard. Fill winglet bottoms |
I started the day sanding and filing the bid and make sure clearances were still good before filler was added (Alpha-poxy and micro balloons). I then sanded the canard and shaped for the first shot of primer sealer. It was now ready and I mixed up the goods and sprayed out 3 coats. I will let set for 3 hours before sanding and adding micro to the low spots. It was time to mix up the Alpha-poxy and ice up the winglet bottoms. |
